AMA SX-2009 Relacje,komentarze.
Autor tematuGracjan
http://wire.ama-cycle.org/
http://206.168.146.115/
http://206.168.146.116/
http://www.amasupercross.com/results/09 ... index.html
http://www.supercrossonline.com/supercrosslive
Bubba znowusz najszybszy na treningu.
Fastest overall Pre-qualifying times
Pos. No. Best time Session Rider name Hometown Bike
1 7 00:48.960 Pre-Qualifier 1 James M. Stewart Haines City, FL Yamaha YZ450F
2 1 00:49.447 Pre-Qualifier 1 Chad Reed Tampa, FL Suzuki RM-Z450
3 2 00:50.107 Pre-Qualifier 4 Ryan D. Villopoto Poulsbo, WA Kawasaki KX450F
4 9 00:50.653 Pre-Qualifier 1 Ivan Tedesco Tallahassee, FL Honda CRF450R
5 29 00:50.672 Pre-Qualifier 1 Andrew T. Short Smithville, TX Honda CRF450R
6 15 00:50.685 Pre-Qualifier 4 Timmy M. Ferry Largo, FL Kawasaki KX450F
7 33 00:50.762 Pre-Qualifier 4 Joshua M. Grant Riverside, CA Yamaha YZ450F
8 14 00:51.158 Pre-Qualifier 4 Kevin W. Windham Centreville, MS Honda CRF450R
9 800 00:51.389 Pre-Qualifier 4 Mike A. Alessi Victorville, CA Suzuki RM-Z450
10 18 00:51.553 Pre-Qualifier 1 David D. Millsaps Carlsbad, CA Honda CRF450R
11 31 00:51.644 Pre-Qualifier 5 Ryan Sipes Vine Grove, KY KTM 450SX-F
12 979 00:51.741 Pre-Qualifier 4 Ben Coisy Murrieta, CA Honda CRF450R
13 79 00:51.818 Pre-Qualifier 6 Cole T. Siebler Emmett, ID Honda CRF450R
14 59 00:51.895 Pre-Qualifier 1 Troy K. Adams Homosassa, FL Honda CRF450R
15 75 00:51.911 Pre-Qualifier 4 Joshua R. Hill Murrieta, CA Yamaha YZ450F
16 27 00:51.995 Pre-Qualifier 4 Nicholas A. Wey Murrieta, CA Yamaha YZ450F
17 38 00:52.113 Pre-Qualifier 3 Kyle P. Chisholm Valrico, FL Yamaha YZ450F
18 13 00:52.158 Pre-Qualifier 4 Heath D. Voss Mico, TX Honda CRF450R
19 921 00:52.326 Pre-Qualifier 5 Manuel Rivas Ceuti Murcia, Kawasaki KX450F
20 37 00:52.387 Pre-Qualifier 5 Antonio Balbi Riverside, CA Honda CRF450R
21 100 00:52.399 Pre-Qualifier 2 Joshua Hansen Las Vegas, NV Honda CRF450R
22 28 00:52.515 Pre-Qualifier 4 Charles J. Summey Huntersville, NC KTM 450SX-F
23 35 00:52.647 Pre-Qualifier 4 Paul P. Carpenter Ithaca, NY Kawasaki KX450F
24 651 00:52.786 Pre-Qualifier 5 Daniel McCoy Saugus, CA Honda CRF450R
25 54 00:52.801 Pre-Qualifier 4 Matt Boni Geneva, FL Honda CRF450R
26 105 00:52.801 Pre-Qualifier 6 Sean D. Hamblin Murrieta, CA Yamaha YZ450F
27 21 00:52.853 Pre-Qualifier 2 Cody Cooper Huntersville, NC Yamaha YZ450F
28 917 00:53.053 Pre-Qualifier 6 Eric Sorby Huntersville, NC Yamaha YZ450F
29 95 00:53.099 Pre-Qualifier 5 Ben E. Lamay Anchorage, AK Yamaha YZ450F
30 677 00:53.464 Pre-Qualifier 6 Jason R. Hussey Moscow Mills, MO Kawasaki KX450F
31 57 00:53.582 Pre-Qualifier 6 Jacob Marsack Berlin, MI Honda CRF450R
32 129 00:53.734 Pre-Qualifier 5 Vernon A. McKiddie Huffman, TX Honda CRF450R
33 99 00:54.165 Pre-Qualifier 6 Jase A. Lewis Carrollton, GA Suzuki RMZ450
34 323 00:54.651 Pre-Qualifier 3 James M. Povolny Jeffersonville, IN Kawasaki KX450F
35 68 00:55.340 Pre-Qualifier 5 Michael R. Blose Phoenix, AZ Honda CRF450R
36 147 00:56.367 Pre-Qualifier 6 Clayton Miller Spring, TX Honda CRF450R
37 395 00:56.666 Pre-Qualifier 5 Benjamin R. Ritter Saint Marys, PA Suzuki RM-Z450
38 523 00:57.273 Pre-Qualifier 5 Dustin E. Gills Wiggins, MS Suzuki RM-Z450
Ostatnio zmieniony czw, 29 sty 2009, 01:39 przez Gracjan, łącznie zmieniany 2 razy.
theNaturat
Autor tematuGracjan
Re: Houston SX links
James Bubba Stewart wygral po raz trzeci.
Kolejna runda mistrzostw AMA i FIM odbyla sie na stadionie Reliant w Texasie.
Stewart ponownie byl najszybszym zawodnikiem na treningu i w pierwszym biegu kwalifikacyjnym ktorym nie dal szans rywalom.Na drugim miejscu zakonczyl Tedesco,trzeci zakwalifikowal sie Windham ktory stoczyl walke z Alessi.Stewart co raz pewniej czuje sie na Yamaha i chce odrobic punkty stracone z pierwszej rundy jak najszybciej jest tylko to mozliwe.W biegu drugim Reed prowadzil od startu do mety mimo ze zgasl mu silnik na jednym z zakretow ale odpalil od pierwszego kopa i nie bylo dramatu.Duza niespdzianka bylo nie wejscie do finalu Nick Way'a ktory jezdzi dla KTM ale prawda jest taka ze jak tylko przesiadl sie z Hondy skonczyly sie jego sukcesy w SX?Przed biegiem finalowym obstawialismy wyscig z paroma znajomymi ja mimo ze bardzo lubie Reeda tym razem stawiam na Stewarta ktory wyglada lepiej na tym torze i tylko jakis duzy blad moze mu odebrac wygrana.Holeshot wygrywa Alessi ale jest wyprzedzony blyskawicznie przez Villopoto.Stewart jest na piatym miejscu ale wyprzedza bardzo szybko zawodnikow nie chce marnowac czasu wie ze Reed ponownie mial bardzo slaby start.Na trzecim okrazeniu Bubba zbliza sie do Villopoto i szykuje sie do ataku wychodzi na moment na prowadzenie ale Villopoto nie chce sie poddac odpiera atak na moment ale to wszystko na co go stac Bubba wychodzi na prowadzenie i oddala sie w blyskawicznym tempie.Short jest nadal na trzecim miejscu.Reed na szostym okrazeniu wyprzedza Grant'a i wychodzi na czwarte miejsce.Bubba prowadzi niezagrozony i ma 10 sekund przewagi nad Reed'em i jak tylko nie popelni duzego bledu powinien wygrac.Reed wykreca te same czasy co Bubba na dziesiatym okrazeniu zblizyl sie do Short'a aby go niebawem wyprzedzic bez wali ale to nie wszystko Villopoto wywraca sie na zakrecie i Reed jest juz na drugim miejscu.Ale roznica miedzy Bubba a nim jest za duza aby cos uleglo zmianie.Wyscig konczy sie podobnie jak w zeszlym tygodniu.Wygrywa Stewart drugi jest Reed a trzeci przekracza linie mety Villopoto jest to jego pierwsze podium w SX klasie.Ogolnie mowiac wyscig bez wiekszych emocji Reed traci kolejne punkty w walce o tytul i ma tylko 9 punktow przewagi nad Bubba.Musi bardzo duzo pracowac nad startami aby nawiazac bezposrednia walke z Bubba ale sezon jest dlugi i wiele jeszcze moze sie wydarzyc.
Houston Supercross results
Pos. No. Rider name Hometown Points Bike Sponsors
1 7 James M. Stewart Haines City, FL 25 Yamaha YZ450F San Manuel / Yamaha / JSE / Bridgestone
2 1 Chad Reed Tampa, FL 22 Suzuki RM-Z450 Rockstar / Makita / Suzuki / Bridgestone / Maxima / Tag / Pro Taper / Alpinestars / One / Mechanix Wear / Showa / Road Champs / CP Pistons / Hinson / RG3 / Snap On / Twin Air / DID / Excel / FCC / NGK
3 2 Ryan D. Villopoto Poulsbo, WA 20 Kawasaki KX450F Monster Energy / Kawasaki
4 29 Andrew T. Short Smithville, TX 18 Honda CRF450R Honda Red Bull Racing
5 33 Joshua M. Grant Riverside, CA 16 Yamaha YZ450F Joe Gibbs Racing
6 9 Ivan Tedesco Tallahassee, FL 15 Honda CRF450R Honda Red Bull Racing
7 800 Mike A. Alessi Victorville, CA 14 Suzuki RM-Z450 Rockstar / Makita / Suzuki / Bridgestone / Maxima / Tag / Pro Taper / Alpinestars / One / Mechanix Wear / Showa / Road Champs / CP Pistons / Hinson / RG3 / Snap On / Twin Air / DID / Excel / FCC / NGK
8 15 Timmy M. Ferry Largo, FL 13 Kawasaki KX450F Monster Energy / Kawasaki Motors Corp
9 14 Kevin W. Windham Centreville, MS 12 Honda CRF450R Geico Powersports Honda
10 18 David D. Millsaps Carlsbad, CA 11 Honda CRF450R Honda Red Bull Racing
11 75 Joshua R. Hill Murrieta, CA 10 Yamaha YZ450F Yamaha Motor Corp / Bridgestone / Factory Effex / Tag / Akrapovic / Yamalube / Vortex / DID / VP / GYTR / Braking / Cycra / Lightspeed / Axio / Mechanix Wear / G2
12 13 Heath D. Voss Mico, TX 9 Honda CRF450R
13 35 Paul P. Carpenter Ithaca, NY 8 Kawasaki KX450F Monster Energy / Cernics / Kawasaki / Pirelli / Moose / Athena / Silkolene / EVS / Motion Pro / EBC / Pro Circuit / Atomic
14 79 Cole T. Siebler Emmett, ID 7 Honda CRF450R Motoconcepts / FMF / FoxRacingShox / Fly / MDK / Pirelli / DeCalWorks / SmoothIndustries
15 54 Matt Boni Geneva, FL 6 Honda CRF450R DNAEnergyDrink / BTOSports / BBMX / RickCaseHonda / FLY / WMI / Bel-Ray / Vortex / Formula / FMF / Smith / Wiseco / StellarMX / ASMF / ASV / Dunlop / Ogio / Applied / Alpinestars / PitPosse / CV4 / Sponsorhouse / ICW / Devol / EngineIce / QTM / Talon / RK / TwinAir / Leatt / KineticAnimation / SeminoleTribeMX
16 979 Ben Coisy Murrieta, CA 5 Honda CRF450R Motoconcepts / FMF / FoxRacingShox / Fly / MDK / Pirelli / DeCalWorks / SmoothIndustries
17 38 Kyle P. Chisholm Valrico, FL 4 Yamaha YZ450F San Manuel / Yamaha / JSE / Bridgestone
18 28 Charles J. Summey Huntersville, NC 3 KTM 450SX-F Jagermeister / MDK / KTM / Motorex / FMF / Pro Taper / Dunlop
19 921 Manuel Rivas Ceuti Murcia, 2 Kawasaki KX450F MDKMotorsports / Kawasaki / WarthogRacingAcademy / ProCircuit / Answer / DeCalWorks / P-LoK / Enzo / Oakley / Bridgestone / MMI / HonaluluHills / Transworld / Smooth / Motoconcepts / CTi2 / Devol / RENTHAL / DT1 / Cycra / CP / Alpinestars / VanquishMX / LiquidPerformance / VP / Motionpro
20 100 Joshua Hansen Las Vegas, NV 1 Honda CRF450R Rockstar / Hart & Huntington / Boost Mobile
Klasyfikacja generalna:
AMA Supercross
Overall points standing
Finish positions shown in parenthesis Series schedule
Pos. Pts. Rider name RD 1 RD 2 RD 3 RD 4 RD 5 RD 6 RD 7 RD 8 RD 9 RD 10 RD 11 RD 12 RD 13 RD 14 RD 15 RD 16 RD 17 RD 18 RD 19
1 86 C. Reed 20 (3) 22 (2) 22 (2) 22 (2)
2 77 J. Stewart 2 (19) 25 (1) 25 (1) 25 (1)
3 77 J. Grant 25 (1) 20 (3) 16 (5) 16 (5)
4 71 A. Short 22 (2) 16 (5) 15 (6) 18 (4)
5 68 R. Villopoto 16 (5) 14 (7) 18 (4) 20 (3)
6 62 I. Tedesco 15 (6) 18 (4) 14 (7) 15 (6)
7 56 T. Ferry 18 (4) 12 (9) 13 (8) 13 (8)
8 53 K. Windham 6 (15) 15 (6) 20 (3) 12 (9)
9 46 M. Alessi 10 (11) 10 (11) 12 (9) 14 (7)
10 42 D. Millsaps 9 (12) 11 (10) 11 (10) 11 (10)
11 37 J. Hill 5 (16) 13 (8) 9 (12) 10 (11)
12 37 P. Carpenter 11 (10) 8 (13) 10 (11) 8 (13)
13 30 H. Voss 14 (7) 7 (14) 9 (12)
14 26 N. Wey 12 (9) 6 (15) 8 (13)
15 22 B. Coisy 13 (8) 4 (17) 5 (16)
16 15 C. Siebler 8 (13) 7 (14)
17 15 M. Boni 7 (14) 1 (20) 1 (20) 6 (15)
18 13 C. Summey 1 (20) 9 (12) 3 (18)
19 10 R. Kiniry 3 (18) 5 (16) 2 (19)
20 9 S. Boniface 4 (17) 5 (16)
21 8 T. Adams 2 (19) 6 (15)
22 7 T. Preston 7 (14)
23 5 J. Hansen 4 (17) 1 (20)
24 4 K. Chisholm 4 (17)
25 3 S. Hamblin 3 (18)
26 3 D. Blair 3 (18)
27 2 M. Rivas 2 (19)
AMA Supercross
Barti
Gracjan jak zawsze profesjonalna relacja
Proponuję abyś zrobil nowy temat o AMA SX '09 i tam zamieszczal relacje i torrenty ze wszystkich rund.
Fajnie by było
Pozdro!!!
Pozdro!!!
"Wykorzystaj szansę, którą dał Ci pech"
piasektt
- Motocykl: YZ250F
Dobrze jeździ vilipoto ale zbyt dużo upadków zalicza. Widać że badzo chce ale jeszcze w 4,5 mu tak nie idzie
Autor tematuGracjan
Mysle ze to niezly pomysl wiec zmienilem temat.Prosze wiec o zamieszczanie wszystkich informacji i torrenty dotyczacych SX pod tym tytulem.Jak ktos bedzie szukal informacji wszystko bedzie bardziej dostepne do znalezienia.Barti pisze:Gracjan jak zawsze profesjonalna relacja![]()
Fajnie by było
Pozdro!!!
Zenko666
- Motocykl: Yamaha YZ250F
Re: AMA SX-2009
Relacja jak na Gracjana przystało ;] aż miło się czyta a co do zawodów to całkiem ciekawe coś Reed'owi starty nie wychodzą i po raz pierwszy podobała mi sie jego wypowiedź
czkam na kolejne zawody a raczej torrenty i relacje Gracjana pzdr.
Było :
Yamaha DT125 1996r
Honda CR250 1999r
Jest:
Yamaha YZ250F 2008r
Yamaha DT125 1996r
Honda CR250 1999r
Jest:
Yamaha YZ250F 2008r
Barti
Re: AMA SX-2009 Relacje,komentarze.
Dla ułatwienia sprawy dorzucam torrenty z 1. 2. i 3. rundy AMA SX 2009
http://www.mininova.org/tor/2147237 - Anaheim 1 Lites i Supercross RUNDA PIERWSZA
http://www.mininova.org/tor/2170484 - Phoenix klasa Lites RUNDA DRUGA
http://www.mininova.org/tor/2171077 - Phoenix klasa Supercross RUNDA DRUGA
http://www.mininova.org/tor/2193196 - Anaheim 2 klasa Lites RUNDA TRZECIA
http://www.mininova.org/tor/2192462 - Anaheim 2 klasa Supercross RUNDA TRZECIA
Pozdrawiam!
Pozdrawiam!
Autor tematuGracjan
San Francisco
Linki
Na treningach Bubba najszybszy
Linki
Barti
I tym razem James Stewart wygrał wyscig finałowy! Jest to jego 4-te zwyciestwo z rzędu! Czekamy na torrenty i relację Gracjana
Ostatnio zmieniony ndz, 1 lut 2009, 20:07 przez Barti, łącznie zmieniany 1 raz.
Zenko666
Małe sprostowanie wygrał po raz 4 z rzędu niestety nie piąty i czekam na torrentyBarti pisze:I tym razem James Stewart wygrał wyscig finałowy! Jest to jego 5-te zwyciestwo z rzędu! Gracjan czekamy na relacje
pzdr.
Było :
Yamaha DT125 1996r
Honda CR250 1999r
Jest:
Yamaha YZ250F 2008r
Yamaha DT125 1996r
Honda CR250 1999r
Jest:
Yamaha YZ250F 2008r
