fajka yz 250
: śr, 4 gru 2013, 21:43
autor: ryba881
Witam, jaka powinna być oporność fajki? Motor to yamaha yz 250 z 1991 roku, na starej nic nie jest napisane. Pozdrawiam.
Re: fajka yz 250
: śr, 4 gru 2013, 21:50
autor: solaris
CDI:
Magneto-(stator) 5CU-02
Source coil 1 resistance Black - Black/Red 720-1080 Ohm at 20 deg C or 68 deg F
Source Coil 2 resistance Green/Blue - Green/White 44-66 ohm at 20 deg C or 68 deg F
Pick up Coil resistance White/Blue - White/Red 248-372 ohm at 20 deg C or 68 deg F
Ignition Coil: 4MX-00
Minimum Spark Gap 6mm or .24"
Primary winding resistance .20-.30 ohm at 20 deg C or 68 deg F
Secondary winding resistance 9.5-14.3 K ohm at 20 deg C or 68 deg F
Spark Plug cap 4-6 K ohm at 20 deg C or 68 deg F <-- to Cie interesuje
Format:
Nazwa elementu / Oporność / Temperatura Pomiaru
