Maico-informacje o motocyklach
Autor tematugajowy
- Motocykl: ktm 300 EXC
Re: Maico-informacje o motocyklach
Maico powraca!!!
![](http://images36.fotosik.pl/36/b5e67b6a31bcfe0cmed.jpg)
![](http://images45.fotosik.pl/36/4962b812c52524e0med.jpg)
![](http://images33.fotosik.pl/416/6efdd7a2914bea43med.jpg)
· Engine … 2 strokes, 1 cylinder
· Cooling …Water
· Exhaust … HGS
· Bore/Stroke … 86.5 x 85mm
· Displacement … 499 cc
· Engine Power … 67 hp at 6500 rpm
· Carburetor … Mikuni TM 38
· Transmission … 5 Speed
· Ignition … PVL for MX - SEM for enduro
· Frame … Chromoly
· Front suspension … Marzocchi Magnum 50
· Front wheel travel … 305 mm
· Rear suspension … Twin link
· Rear wheel travel … 320 mm
· Rear Brake … Brembo, 220 mm Disc/single, floating piston
· Front Brake … Brembo, 260 mm Disc/double floating piston
· Tank capacity … 9.5 liter
· Wheelbase … 1480 mm
· Ground clearance … 388 mm
· Seat height … 960 mm
· Weight … 100 kg/MX - 111 kg Enduro
TECHNICAL SPECIFICATIONS MAICO 250 250 Cross and 250 Enduro
· Cooling … Water
· Exhaust … HGS
· Bore/Stroke … 67 x 70mm
· Displacement … 250 cc
· Engine Power … 53 hp
· Ignition …PVL/MX model - SEM Enduro model
· Frame … Chromoly
· Rear Brake …Brembo , 220 mm Disc/single floating piston
· Weight … 97 kg MX model - 109 kg Enduro model
· Cooling …Water
· Exhaust … HGS
· Frame … Chromoly
· Cooling … Water
· Exhaust … HGS
· Frame … Chromoly
![](http://images30.fotosik.pl/301/5626a029571fd07cmed.jpg)
Model: Maico 320 Enduro
Cooling: Water
Inlet system: Reed walve system
Exhaust system: S.E.E.S. exhaust system
Cylinder capacity: 318ccm
Measures: 76 x 70mm
KW/horsepower: 13/17 - 36/54
Caburator: BING 40 oval
Transmission: 5 speed gearbox
Ignition: 12V / 130W SEM
Frame: Chrom Molybdän
Front fork: White Power Extreme 50
Front wheel travel: Brembo 260mm
Front rim: 1.60 - 21
Front tyres: 90/90 - 21
Rear suspension: Maico Twin Link White Power
Rear brake: Bremo 220 mm
Rear rim: 2.15 - 18
Rear tyres: 140/80 - 18
Tank: 9,5 Liter
Wheel base: 1480 mm
Ground clearance: 388 mm
Seat hight: 960 mm
Weight: 109 kg
![](http://images27.fotosik.pl/300/e0844ed722b9587fmed.jpg)
Model: Maico 620 Enduro
Cooling: Water
Cylinder capacity: 620 ccm
Measures: 95 x 87mm
KW/horsepower: 56/76
Caburator: BING 44 mm
Front fork: White Power Upside Down 48 mm
Front brake:Brembo with 260 mm wave disc
Rear suspension: Maico Twin Link with Reiger shock
Rear brake: Bremo with 220 mm wave disc
Rear rim: 2.15 - 18
Tank: 9,5 Liter
Wheel base: 1480 mm
Seat height: 960 mm
Weight: 111 kg
- Motocykl: Honda CR480r
Maico zawsze robiło mocne sprzęty. 620cc w 2t to nieźle. Pewnie ok 70-80KM. Od kiedy pamiętam w ich silnikach zawsze były gaźniki bing. Szkoda że z przodu w zawieszeniu ma zwykłe teleskopy a nie usd. Co tu dużo mówić kultowy sprzęt.
- Motocykl: CRF250R '06
W sumie nie wiem czemu tak zrobili w tym modelu. Ja miałem starsze Maico a jednak był Upside-Down. Dla zainteresowanych, sprzedażą motocykli Maico oraz częsciami do nich zajmuje się Kostler - http://www.maico-bikeworld.de/catalog/
Było: Komarek
Było: Komarek
![Smile :)](./images/smilies/icon/smile.gif)
