Modele 2010
Autor tematuFajka
Modele 2010
Husqvarna na rok 2010 prezentuje 7 nowych modeli Enduro i 3 do Motocross-u aby zaspokajać potrzeby najbardziej wymagających terenowych entuzjastów. Są to prawdziwe repliki maszyn, które ścigały się w zespole Husqvarny w Mistrzostwach Świata.
motocross - TC250, TC450, CR125
off road - TE250, TE310, TE450, TE510, WR125, WR250, WR300
Motocross Updates for 2010
* New IPD (in–mould plastic decoration) graphics on tank sides and race number plate
* New stronger, more flexible plastics
* New 48 mm Kayaba forks with new triple clamps
* New exhaust system and silencer (CR125)
* Frame reinforced in the high stress areas
* New stronger, lighter front and rear wheel hubs
* New stronger front and rear wheel spindles
* Rear swing arm shortened by 15 mm (TC450) to improve traction and handling
* New rear disc (TC only)
* New radiator connectors and coolant hoses (TC450)
* New high performance water pump for improved cooling system efficiency (TC450)
* New Sachs rear shock absorber (CR125)
Enduro Updates for 2010
* TE250 Completely new model with fuel injected engine
* New 48 mm Kayaba forks and new triple clamps (excluding WR125)
* New more powerful front headlight design (TE models only)
* New rear mudguard with two part integrated number plate holder for a more aggressive, compact look (two part design allows swift conversion from homologated form to race form)
* New rear lamp cluster with more powerful/better-protected LED lights
* New exhaust pipe (WR125 & WR 300) for improved power distribution
* New silencer (WR125)
* New optional high capacity fuel tank for WR125 & TE250
* Frame reinforced in the high stress areas (WR125, all TE models)
* Rear swing arm shortened by 15mm (TE models) to improve traction and handling
* New rear disc (TE models only)
* New radiator connectors and coolant hoses (TE models only)
* New high performance water pump for improved cooling system efficiency (TE models)
* New Sachs rear shock absorber (WR125)
- Motocykl: KTM SXF 350
Re: Modele 2010
Siemanko!!! Podłączam się pod temat oto pierwsze zdjęcia suzuki i kawasaki 2010 .
Suzuki RM-Z 250 podobna do 450 i jest to pierwsza 250 na wtrysku. :finga: oto linki:
http://www.vitalmx.com/product/feature/ ... odels,2496
Oraz suzuki wypuszcza pierwsze hard enduro o pojemności 450 ,Suzuki RMX450Z na wtrysku z rozrusznikiem
Modele kawasaki :
http://www.vitalmx.com/product/feature/ ... odels,2493
Wybrane zmiany w 450 KXF:
* NOWY fabrycznie przeprowadzony tuning silnika
* NOWY regulowany ECU (komputer sterujący pracą silnika)
* NOWE łatwiejsze w prowadzeniu zawieszenie
* NOWE zmodyfikowane przednie i tylne zawieszenie oraz możliwość ich regulacji
* NOWE sprzęgło
Wybrane zmiany w 250 KXF:
* NOWE przednie zawieszenie marki SHOWA
* NOWY tylny amortyzator
* NOWE tylne zawieszenie typu Uni-Trak
Teraz czekamy jeszcze na Yamahę i Hondę.
Ja osobiście nie mogę się doczekać na Suzuki. :finga:
Modele kawasaki :
* NOWE sprzęgło
Re: Modele 2010
Ja te zdjecia znalazlem pod opisem yz450f 2010 ale dla mnie to chyba raczej jest husaberga na 1 phota na 2 juz cos bardziej przypomina yz w ogole przod to wyglada jak kawa z 08
pozdro
p.s śmieszne, dziwne no i pomysłowe te rozwiązanie z układem wydechowym
pozdro
Suzuki RM-Z 250 2011.
KTM EXC 450 2012.
KTM EXC 450 2012.
Re: Modele 2010
To Yamaha z 5 zaworów zrobila by 4?
Honda CRF250r
Yamaha YZ250F
THE POLISH NIGHTMARE #715
www.mxFOLGA.pl
LIFESTYLE na FB
Yamaha YZ250F
www.mxFOLGA.pl
LIFESTYLE na FB
Re: Modele 2010
CRF250r 2010
Jak ktos powie jak to ominac to bedzie super
FILMIK na YouTube
Wszystkie 2010
http://motocross.transworld.net/2009/03 ... &nggpage=4
To wtrysk seryjnie bedzie w KX250F i RM250Z, a w opisie CRF250 tez jest wtrysk ale nie bedzie robiony seryjnie??
Ciekawe ile w tym prawdy.
FILMIK na YouTube
Wszystkie 2010
Ostatnio zmieniony pt, 26 cze 2009, 19:34 przez Jony, łącznie zmieniany 2 razy.
Honda CRF250r
Yamaha YZ250F
www.mxFOLGA.pl
LIFESTYLE na FB
Yamaha YZ250F
www.mxFOLGA.pl
LIFESTYLE na FB
Re: Modele 2010
Jony pisze:CRF250r 2010
FILMIK na YouTube
Wszystkie 2010
http://motocross.transworld.net/2009/03 ... 0-preview/
Z tego co wyczytałem to wtrysk ma być w RM-Z 250 i CRF 250. Natomiast w KX250F nie będzie go.
Re: Modele 2010
"This weekend, the standout bikes were the Kawasaki KX250F and Suzuki RM-Z250s, both of which featured electronic fuel injection."
A KX250F ma miec:
"Aside from the EFI throttle body, the Kawasaki KX250F piloted by Shin Inouye looked much like an existing ’09 KX250F"
A KX250F ma miec:
Honda CRF250r
Yamaha YZ250F
www.mxFOLGA.pl
LIFESTYLE na FB
Yamaha YZ250F
www.mxFOLGA.pl
LIFESTYLE na FB
Re: Modele 2010
2010 Kawasaki KX250F Specifications:
Engine: Four-stroke single with DOHC and four valves
Displacement: 249cc
Bore x stroke: 77.0 x 53.6mm
Cooling: Liquid
Carburetion: Keihin FCR37 and hot start circuit
Displacement: 249cc
Cooling: Liquid
- Motocykl: bmw g450x
Re: Modele 2010
w kxf 250 nie bedzie wtrysku, bo nie daje to takiej poprawy charkterystyki jak w 450. a koszty duzo wieksze i sie nie oplaca.
- Motocykl: YZ250F
Re: Modele 2010
Mam dla was HICIORA !!!
SUPER ŚCIŚLE TAJNE ZDJĘCIE
YAMA 2010
450F:
Elektryczny rozruznik, nowy "piec" <4zawory>, oczywiście wtrysk itd.
YAMA 2010
450F:
- Motocykl: EXC-R 530
Re: Modele 2010
to jakiś żart?piasektt pisze:Mam dla was HICIORA !!!
YAMA 2010
450F:
www.motocross.wroclaw.pl
Re: Modele 2010
Honda crf 250 2010
Całkowicie nowy model na wtrysku, z wyglądu podobna do 450.
oto link: http://www.vitalmx.com/product/feature/ ... F250R,2503
A co do piasektt, ktoś tu nie umie bawić się photoshopem.
